User_499247 | Second Level Floor PlanUser_499247 2015-01-26 00:14:33 I already created a Ground Floor Plan. I like to know how to create a Second Level Floor Plan. |
Patricio | Patricio 2015-01-28 18:28:07 New project levels have to be inserted in the Height Reference System. Proceed as follow: - In the Tools menu select LEVELS Manager (HRS); - Select the “Ground Floor” node; - Select the “Insert LEVEL” option; - Rename the “Level 1” node; - Define the “Ground Floor” height to establish the elevation of the upper Level. Watch this video to see how to create new levels: video.accasoftware.com/EN/edificius/id3/index.html?idPLV=4194&autoplay=1 Once the new Level is realized (for example the Second Floor) to copy on it the things designed on the level below (for example First Floor) is necessary to proceed as follow: - place on the Level from where you would copy the objects; - select the “Copy” toolbox; - indicate the entities that you have to copy; - indicate the Level where you will copy the entities. Watch the video to see how to copy the objects from a level to another: video.accasoftware.com/EN/edificius/id28/index.html?idPLV=312&autoplay=1 |
