John | Objects shown in Floor Plan viewJohn 2015-01-16 14:58:10 I'm sharing a new thread for our technical support cases QUESTION: which objects are represented in floor plan view? ANSWER: in the drawing model views, the following objects are represented: - sectioned objects from the horizontal section plane; - All those objects that are at a lower altitude than that of the floor plan and only if not covered by other objects For such a reason, you can't view those objects that are above the horizontal section plane in floor plan view. |
Tony | Tony 2024-01-16 17:34:06 I think you can reach a good level of detail by using the "Construction Detail" object in the Drawing Models (floor plan, section view, elevation views, etc) object menu - see screenshot: section_construction_detail.jpg Once inserted, it will generate a SubNode where you can see the section and add extra 2D detailing if necessary. section_construction_detail_001 See if that works for you. |
