Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
Maurice
Project Group message: individual file change
Maurice 2017-11-24 10:40:39
Technical support case
Question:
When a Project Group is opened, the following message appears:
WARNING
The file "file.EDF" has been modified individually. The relating Project Group may not work properly.
what does it mean?
Answer:
If this message appears when opening a Project Group, it means that the "Surveyed stage", the "Design stage" or both, have been edited "individually".
Depending on the changes made, the Project Group may not function properly due to, for example, demolished elements, such as doors and/or other similar misalignments.
When dealing with Building re-modellings and renovation works, the Project Group files should never be opened individually.
N.B.
When saving a single document, the following message appears:
Editing Project Group files individually may cause errors in the project. Do you want to continue?
