John | How to rotate a Panel objectJohn 2014-12-16 09:19:57 A new technical support issue requesting help with rotating a Panel object QUESTION: How can I rotate a Panl enity used as a Solar Panel in my project? ANSWER You can easily rotate a Panel object from directly within the 3D view using the object grips Proceed as follows: - select the panel; - select the axis (3D) around which to rotate; - withthe extension guide line align the panel according to the roof inclination. Watch this video tutorial to see how it's done in the 3D working environment: video.accasoftware.com/EN/edificius/id2/index.html?idPLV=204&autoplay=1 |
