Here's a new technical support issue that I want to share with our Edificius users
Question: I downloaded from the a 3D Model from the On-Line Catalogue but I'd like to scale it to the desired dimensions. How do I do that ?
Answer: To change the size of a 3D Model simply proceed as follows: - Select the 3D Model where the model was loaded either USER or PROJECT CATALOGUE; - Choose "Edit Model" from the "Properties" toolbox; - From the 3D model Edit window change its dimensions (length, width and/or height); - Remove the "check" from "Keep Aspect Ratio" if you want to change the individual dimensions without preserving the aspect ratio between length, width and height; - Confirm with OK to make the changes to the 3D Model permanent.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
