Forum
Maurice
TERRAIN Modelling Environemnt: contour lines and/or elevation nodes not recognised in a DXF/DWG CAD Drawing
Maurice 2017-10-23 11:53:27
Technical support request
Question:
TERRAIN Environment: after loading a DXF/DWG CAD Drawing, I've noticed that my contour lines and/or elevation nodes aren't detected when using the magic wand tool
Answer:
To generate the "Contour lines" and/or "Elevation nodes" from a DXF/DWG Drawing in automatic simply load the DXF/DWG using the "DXF/DWG survey" feature , present in the Terrain environment's Object Menu and NOT the "DXF/DWG Drawing" tool available in the program's "2D GRAPHICS" menu.
