Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
Maurice
Assign a HATCH to a Stratigraphy or a material
Maurice 2017-06-09 09:54:14
I want to share a support request.
Question:
I would like to assign and/or edit a HATCH in a Stratigraphy and/or a Material, how do I proceed?
Answer:
To assign or change a HATCH for a Stratigraphy and/or a material simply proceed as follows:
For the stratigraphy:
- Open the CATALOGUE;
- Open the "stratigraphy" section;
- Open the stratigraphy to be modified;
- Open "Part Sectioned" from the "properties" toolbox;
- In the "hatch" field load the pattern type that you want to use.
Note: The pattern assigned to the stratigraphy will be displayed in plan views, cross sections, etc. within the thickness of building envelopes, walls... horizontal envelopes etc.
For MATERIALS AND COLORS:
- Open the section "Materials and Colours"
- Open the material that you want to change;
- In the "pattern" field, simply load the pattern that you want to use.
Note: The pattern assigned to the stratigraphy will be displayed in plan views, cross sections, etc. and on the objects to which the previously modified material was assigned.
