Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
Maurice
How to change the Terrain thickness
Maurice 2017-05-30 16:50:39
Here's another interesting technical support case that I wanted to share with our users.
Question:
Is there a way of changing the default Thickness of the Terrain layer?
Answer:
Yes, you can modify the default thickness of the Terrain Survey level (set as default at 2,000 meters). To change this value, proceed as follows:
1] Open the "Terrain" Modelling environment;
2] From the "00 SURVEY" level, select the TERRAIN marker [source]:
3] From the "Properties" Toolbox select "Characteristics" > "Thickness";
4] Enter the required value.
In the example below shows the LAND with the default thickness of 2,000m (A) and the modified thickness of 7,000m (B):
"A"
" B"
