Here's another interesting topic that many of our users are curious to get an answer to.
Question: I need to insert a Flowerbed in my project. Is there an easy way to do this?
Answer: Yes, you can proceed in this very straightforward manner:
1] Open the "TERRAIN" modelling environment and select a "Project" level;
2] Now select the "Flower-bed" object from the objects menu (;
3] Simply trace the object's perimeter in the 2D or 3D view;
4] Select the flowerbed object. Then, in the "Properties" Toolbox, define its elevation above ground level, its depth and the wall composition details including materials etc. (Levelled walls, sloped, stepped);
5] You can also add a "Wall Cap" finish automatically using the “Solid” command () also available from teh multi-function toolbar;
6] Even add a "Railing" automatically along the entire flowerbed perimeter too ();
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
