Here's an interesting Technical support issue that I wanted to share with our Edificius users
QUESTION: I need to create a Building envelope where one side is straight and the other curved.
ANSWER: To model this kind of wall, you simply need to follow these few steps: 1] draw the envelope object in the desired level; 2] select it; 3] in the "Properties" toolbox select "VARIABLE THICKNESS"; 4] select the vertices and assign the desired thickness:
5] now select the segment that you want to convert to "curve"; 6] select "Edit" > "Convert to Arc"; 7] modify its position from the centre point and assign a curvature radius:
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
