Maurice | Curtain wall with wall sectionMaurice 2017-02-03 11:12:15 Here's another technical support issue that I wanted to share with our users QUESTION: I need to create a "curtain wall" that doesn't cover the entire floor elevation height because the base is "n" centimeters high and composed of a certain "material". How do I proceed? ANSWER: You can address this kind of issue creating a "Curtain Wall" with a solid structure part as follows: 1] select the previously inserted "Curtain Wall" object; 2] in the "Properties" toolbox > "Geometry" > "OFFSET" insert the value in millimeters for the section to be shown as "solid" (Left, Right, Top, Bottom). |
Tony | Tony 2024-01-11 09:44:14 Hi Gador, the modelling tools are quite flexible to use and I'm just sharing a simple example of how to use the editing features directly within the BIM objects Library and its Editor. If you need more help with a specific design, just let me know. curtain_wall_editing_the_basics.zip |
