Here's a new technical support case that I wanted to share with our users
QUESTION: In a ROOM, or more in general in a Level, I need to start inserting surface measurements with a "Custom" shape and then obtain a Tag that goes with it. How do I proceed?
ANSWER: To get your surface measurements, proceed as follows: 1] from the main toolbar, select the "Surface Measurement" option - available in the "2D Graphics" sub menu; 2] now simply trace over the surface to measure using the snap points in corners or provided by surrounduing entities, etc., then click Finish" to close the area;
3] select the area and from the option present in the "Properties" toolbox now customise your "Text", "Colour", etc.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
