Forum
Maurice
Adapting Walls to the Roof slope
Maurice 2017-01-09 17:10:55
Here's and interesting case for our users
QUESTION:
I've set up a roof top and would like to have my walls adapt to the bottom face of each roof slope. Is there a work around for this with out having to adapt each wall manually?
ANSWER:
Edificius allows you to "cut" the excess part of a Building envelope object, such as a wall, as follows:
1] Select the building envelope object (also applies when using an "ornamental wall");
2] In the "Properties" Toolbox > "Height Reference System" > "UPPER" > "sub level" select the Roof ID to which you want the selected WALLS to adapt;
