Here's another technical support case that I wanted to share with our Edificius users
Question: I've produced a rendering from a "scene Photomontage" using these resolution parameters in pixels: Width: 1920 - Height: 1080 check the rendered image's size, it appears to have been modified for some reason. In fact, I get: Width 1600 - Height 1200. What am I doing wrong?
Answer: When producing renderings from a scene photo montage, the maximum resolution of your rendered image is the same as the photo used as your scene. For example, if you use a 1600x1200 pixel image as your background, your rendered image will also have that resolution.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
