Here's another interesting Technical Support case for our Users
Question: I need to represent transparent areas within a material that I'm using. How do I proceed?
Answer: In order to create a hole in a texture map, simply proceed as follows: - With an image editing software create a new file with a 1024*1024 resolution; - Apply a "WHITE" color background; - Now draw the shapes that you want to represent as "HOLES" in Black; - Save the image in the .png, .jpg, .bmp etc; - Open Edificius and go to the CATALOGUE node (USER or PROJECT) and under materials and colours load your custom material; - Select the TEXTURE and under "Properties" go to the "Transparency" section; - In "Transparency" select "Perforations/holes" > "Image" and upload the image that you previously created; - cofirm and now Apply TEXTURE to the desired object; - View the effect in the RTBIM view.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
