John | How to import a Cadastral MApJohn 2014-09-11 18:49:44 Here's a new useful topic that I wanted to share QUESTION Is it possible to use a cadastral map with the terrain perimeter. ANSWER You can import a cadastral map as a Raster image (.jpg). Here are a few videos that show how to proceed: video.accasoftware.com/EN/edificius/id37/index.html?idPLV=2871&autoplay=1 Furthermore, to view the terrain contour lines so as to insert the cadastral map on a specific Level, simply follow this procedure: - access the level; - open the "Background" toolbox - vertical curtain window to the right; - select the "TERRAIN" level in the "Levels to View" section; - click "apply". See this video to understand how to use the "Background" toolbox: video.accasoftware.com/EN/edificius/id28/index.html?idPLV=1790&autoplay=1 |
