BrentPaul | Creating spherical or partial spherical entitiesBrentPaul 2016-04-14 17:23:31 How would I go about creating roof domes, or curved supporting beams and columns? I don't want complex toroidal or multi-curved surfaces though. (Well, at least not yet!) |
John | John 2016-04-15 10:05:48 You can insert these kind of objects by using a 3D model. Of course, you can try downloading a predefined model or you can model what you need using the SketchUp integration feature. Click here to see how to import a 3D model: video.accasoftware.com/EN/edificius/id24/index.html?idPLV=5912&autoplay=1 Here's how to activate the sketchup integration process: video.accasoftware.com/EN/edificius/id65/index.html?idPLV=7332&autoplay=1 |
BrentPaul | BrentPaul 2016-04-17 09:27:43 I don't have time left to learn Sketchup as well right now, haha. I'll definitely search for quality 3D libraries online though; maybe Sketchup's online resource. Can you recommend any libraries? I had a fiddle with the 3D Spherical MagneticGrid tool. When I've used Edificius a while longer, then I'll know how to make more use of that tool for curved designs. Those 2 videos are quite helpful, thank you. PS Where did the following DXF come from in the Magnetic Grid Auto-detect DXF video >> 333033_1460877865_3d_maggrid_and_dxf_import.gif |
John | John 2016-04-18 10:32:32 To insert a typical Vault structure, I'd suggest inserting it as a 3D Model. Have a look at this video showing how to proceed: video.accasoftware.com/EN/edificius/id24/index.html?idPLV=1744&autoplay=1 You can open the 3D Models library directly in Edificius. Have a look at this video: video.accasoftware.com/EN/edificius/id24/index.html?idPLV=5912&autoplay=1 Furthermore, you can insert 3D Models in any format: video.accasoftware.com/EN/edificius/id24/index.html?idPLV=1745&autoplay=1 The DXF drawing used in the video is just an example made for the purpose of this video. You can also have a look in the EdiLus examples folder (C:\ACCA\EdiLus\Examples). |
BrentPaul | BrentPaul 2016-04-19 07:39:00 Thanks for those videos. I watched them again more closely after your recommendation. Then I had a go importing a couple of 3D models using the 3DWarehouse integration feature of Edificius. However, it gave an error message about newer software versions. I tried Sketchup 2015, 2014, 2013 models through the dialog import box but to no avail. See attached screenshot >> 333033_1461044053_newer_version_of_sketchup_for_model_into_edificius.gif I'm using Edificius v.7.00b so what is happening? |
John | John 2016-04-19 14:58:47 dear sir, please try downloading a SketchUp model in Version 8 (3D warehouse lets you choose) or try installing SketchUp 2016 Let us know how it goes. Best Regards |
