This is technical support case sent by one of our users
QUESTION: I need to model a Louvre window but without the external frame. Is there a way of doing this?
ANSWER: Yes, you can. Simply proceed as follows: 1] In the project navigator, select the 3D view (default); 2] select the window; 3] From the "Properties" toolbox click and select "2° fixture model"; 4] Click the "Opens the project catalogue editor" button (pen and paper icon); 5] Select the "Frame" node under the "Structure" section to the bottom right; 6] Deselect "Frame" in the Properties toolbox; 7] Confirm changes using the green Check - top center; 8] Open the 3D view.
A: Louvre Window WITH Frame B: Louvre Window WITHOUT Frame
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
