QUESTION: Is there a way of inserting a line of trees?
ANSWER: Yes, you can and to do so, choosing among the various tree types, bushes and plants, etc., simply proceed as follows: 1] access the "TERRAIN" modelling environment. 2] Open or create a PROJECT LEVEL . 3] From the objects menu, select "Vegetation". 4] From the "properties" toolbox, select the number of different vegetation types (max 3). 5] now choose the different model types. 6] choose whether to insert the vegetation along a Poly line or within an area. 7] now set "Density", "Size", "Scattering" and "Inclination". 8] draw the poly-line within the Level or in 3D view and press "Finish" to conclude vegetation input.
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
