Forum
Maurice
How to change the drawing model representation scale
Maurice 2015-12-29 15:42:10
Here's a new technical support issue.
Question:
How can I print my drawings using a drawing scale different to the default settings (1:100)
Answer:
You can change the drawing scale by following this simple procedure
1. open the Drawing Models node
2. open the drawing models (AREA PLAN, FLOOR PLAN, CROSS SECTION, ELEVATION or ISOMETRIC);
3. from the Properties toolbox select "entity scale" to select the desired scale.
Working drawings must be managed by setting individual drawing scales for each drawing model
User_554537
User_554537 2015-12-30 13:39:10
Thankyou......
Maurice
Maurice 2015-12-30 16:46:16
Your welcome!
