morisdidonato | How to import 3D Models downloaded from the internetmorisdidonato 2025-03-17 14:20:16 I would like to share a request for assistance. QUESTION How can I import a 3D block downloaded from the internet into Edificius? ANSWER To import a 3D Model that has been previously downloaded from the internet, you need to: - Access the "BIM Object Library - Project" from the Navigator; - Select the "3D Models" category from the menu; - Create a new folder; - Add a new item to the folder; - Click on the three dots “…” in the "import from file" field in the properties toolbox; - In the dialog window, select the downloaded 3D Model; - Set the unit of measurement (m, cm, mm) for the Model; - The "3D Model import" window allows you to view and adjust the Model's dimensions; - Confirm the insertion of the 3D Block by clicking "Apply". It is possible to import 3D Model created with solid modelers in the most common formats (.skp, .dae, .obj, .3ds, .dwg, etc.). Watch the video that shows how to operate: Importing 3D Models To import 3D Model created with Revit(.rfa, .rvt) follow the instructions in the following discussion: How to import Revit blocks into Edificius |
