John | Beam with a shaped endJohn 2014-04-11 09:35:33 In this discussion, I'm sharing this Technical support Request. QUESTION How can I model a Roof Beam with a shaped extremity ANSWER To create a profile to assign to the end part of a beam, simply insert the "Solid Extrusion" object. Watch this video to see how to operate: video.accasoftware.com/EN/Edificius/index.php?cat=50&idplv=4052&autoplay=1 |
User_581563 | User_581563 2016-01-24 06:46:27 hi! for sme reason when I append an element, I do not have the edit icon in the upper bar of the box (above the new element) that is pictured in the video. Hencem I cannot draw the profile< Is there also a way I can draw a wall where one of the end is not vertical, as it rests on a beam zith a vertical inclinaison? Txs for help |
John | John 2016-01-27 17:45:48 dear sir, if you can't see the edit button that's probably because one of the two side panels (inspectors) is covering it up. Please try to resize the toolboxes... Have a look at these videos to see how to change the wall footprint in plan view: video.accasoftware.com/EN/edificius/id4/index.html?idPLV=10713&autoplay=1 and then how to change it's shape in elevation: video.accasoftware.com/EN/edificius/id4/index.html?idPLV=239&autoplay=1 |
