User_1664401 | Connection issue while changing delta.User_1664401 2024-04-30 09:25:45 When we change the delta of the pipe, the pipe connection changes. 844600_1714461732_inkeddelta_issue_1_li.jpg844600_1714461742_inkeddelta_issue_2_li.jpg |
Tony | Tony 2024-04-30 09:55:39 Hi, Sorry, I'm seeing the Pipe connection with an elbow joint which seems to be correct. Can you show me in a little more detail before Delta Variation and after? |
User_1664401 | User_1664401 2024-05-02 08:21:04 kindly find the attached video file.844600_1714630859_fitting_issue_while_changing_delta.rar |
Tony | Tony 2024-05-03 10:27:02 Hi, thanks for your patience. When dealing with multiple objects, the delta moves the center of each element by the specified value. As a result, they separate from each other. Try using the 'Move' function with the Z value in the specific field. See screenshot: Function_move_z.png |
User_1664401 | User_1664401 2024-05-03 11:53:12 Hi, As per your solution, I am able to move the overall pipe with the fitting, but I need to reduce the length of the vertical pipe with the fitting. Kindly find attached video (do you have this type of process as shown in video)844600_1714729857_r_fitting_solution.rar |
Tony | Tony 2024-05-03 14:14:42 Thanks for that! I see what you mean now. Well we have the BLUE object grips that support Displacement along a certain Axis. Check out the Video. Regards |
User_1664401 | User_1664401 2024-05-06 06:42:42 Thanks its working. |
Tony | Tony 2024-05-06 09:39:49 Thanks for your feedback! |
