Forum
User_1664401
variable meaning and detail guide for set variable formula
User_1664401 2024-04-22 11:25:56
WE NEED TO UNDERSTAND HOW VARIABLES WORK IN FORMULA WHAT IS SETTING FOR MORE UNDERSTAND ABOUT FORMULA PLEASE SHARE US BASIC ABOUT VARIABLES. 844600_1713777953_22042024_145306_rec.png
luisfornez
luisfornez 2024-04-30 13:00:51
Thanks for writing in regards to MEP labeling.
Keep in mind that if you want to load multiple pipes dimensions or object specifications the best way is to use a "table for pipes".
Naturally you'll need to customise the table for the set of pipes that you specifically want to load. An example can be found here with a door table workflow:
1 - Inserting a legend: video.accasoftware.com/EN/edificius/id705/index.html?idPLV=11115&autoplay=1 [^]
3 - Customise a legend: video.accasoftware.com/EN/edificius/id705/index.html?idPLV=11116&autoplay=1 [^]
Please begin by inserting a legend that is available as a template. This will help you to customise it with a lot of work all ready set from the beginning. Here are 3 steps to do so:
03_Template_Pipe_Legend
Once this is done you can delve into the list of parameters and variable since you'll be able to see the result on the Legend itself.
Please do not hesitate to write in you have any doubts.
Regards,
luisfornez
luisfornez 2024-05-03 17:13:38
Thanks for writing back. The "Customise a legend" video provided, shows how to access the Variables on the Table or Legend. Please check: 01_Opening_Variables_on_Legend_min1.10.png image.
In regards to your last image you provided, "formulas for areas, length or other parameters" question you'll notice that this "Variables" top right button, opens the relative variable from where they are clicked. Please go to: 02_Open_Variables_Window.png. Here I'm signaling the "inner diameter" for the pressurized pipe.
Similarly, in labels' variables, once you select "MEP Labels" to insert and click on the object, you may edit the label adding then the Variable that most suits your requirement. Check: 03_Labels_Variables_Insert. There, you may add other text to complete your required Label, importing several corresponding variables as need it.
Please do not hesitate if you have any doubts in regards to further working with variables.
Best Regards
