User_1664401 | MEP ANNOTATION AND TAGGINGUser_1664401 2024-04-22 11:20:52 WE NEED TO KNOW HOW WE CAN ON ALL PIPE OF 25 NB ON FLOOR WITH 25MM DIA TAG AT SAME TIME WITH MULTIPLE SELECTION OF 25nb PIPES IN SAME LEVEL WE ALREADY WATCH ALL YOUR VIDEOS BUT DONT FIND SOLUTION BASED VIDEO FOR SAME SUBJECT 844600_1713777592_22042024_144824_rec.png sample drawing attached in query |
luisfornez | luisfornez 2024-04-30 12:50:36 Thanks for writing in regards to MEP parameters. We have included a video tutorial on how to Load and Customise pipes Legend on your next Support Case: 206381. Yet here are 3 steps to access the Legend Composition window to customise your Pipes Legend: 1.- Once you insert a pipe's legend (image:01_Load_Table), may I suggest from and existing template, as shown on image 02_Select_Pipes_Object_Legend and inserted on your Floor Level. See image: 03_Template_Pipe_Legend_insert 2.- Then you can customise as shown on image: 04_Pipe_Legend_EDIT (right click on the legend) and accessing the Legend Composition window image: 05_legend_composition_window The following customising workflow can be seen here: Customise a legend: video.accasoftware.com/EN/edificius/id705/index.html?idPLV=11116&autoplay=1 [^] [^] Best regards, 828888_1714474180_01_load_table.png 828888_1714474201_02_select_pipes_object_legend.png 828888_1714474220_03_template_pipe_legend.png |
Tony | Tony 2024-05-02 10:21:59 Thanks for your feedback! |
