Forum
morisdidonato
Title: Edificius-CAD: Printing Custom Sizes
morisdidonato 2024-04-19 14:32:55
I want to share a support request.
Request
How can I customize printing on Edificius-CAD?
Response
Edificius-CAD does not have a preloaded system printer for exporting to PDF. To create a PDF or customize print sizes, you need to install a "virtual printer" on your PC, such as PDFCreator, which allows you to obtain a PDF file as output. After installing and selecting PDFCreator as your printer, you can choose the paper size from various standard/formatted formats (ISO, ARCH, A0, A1, etc.).
To create a print with custom dimensions, proceed as described below.
A) Printing Custom Sizes from Template:
1. Click on print, choose PDFCreator as the printer, and click on "Properties";
2. In the "Settings" tab, click on the "Custom Properties" button;
3. By clicking on "Advanced," you can choose the paper format ""Custom page size PostScript"";
4. Define the dimensions, confirm the changes, and assign a name to the .PC3 file containing the assigned print settings.
B) Create a Layout with Custom Sizes:
1. Right-click on the Layout tab to modify;
2. From the dropdown menu, choose "Page Setup Manager";
3. Select "Add..." or "Edit...";
4. Follow the steps already described for example A.
