Forum
morisdidonato
2D Graphics: Setting Up Custom Templates
morisdidonato 2024-03-29 15:39:49
I want to share a support request.
Request
How can I set up a dimension style to use on all my projects?
Response
In Edificius, you can define custom templates for 2D Graphics objects. These configurations are saved in a new manager and are immediately available for all documents. You can create your own configurations for Labels, Texts, Dimensions, etc., to use as accelerators both during insertion and modification.
How to Proceed:
1. Creating the Template Click HERE
- Customize the 2D graphics object (e.g., Linear Dimension);
- Select the customized object;
- On the top multifunctional bar, in the Templates field, click the Add button;
- Define the template name and confirm.
2. Choosing the Template  Click HERE
- Select the 2D graphics object (the Linear Dimension);
- Click the Load button;
- Choose from the created templates.
3. Modifying/Deleting the Template  Click HERE
- Click the Edit button to rename, update, or delete one or more existing templates.
