Hemant | 3ds MAX file import into EdificiusHemant 2023-07-11 14:23:57 How can I import 3DS MAX File into Edificius? |
Tony | Tony 2023-07-11 14:44:13 You can't import 3DS MAX files - When needing to add extra 3D assets to your Edificius 3D BIM models, you can import any of the different formats as listed in attached image. With a 3DS Max object (within the max number of polygons and texture sizes) I would suggest you convert it using your 3DStudio Max to one of the many compatible formats as listed. 3D format files.jpg |
