Forum
Helping others, engage in discussions, share your experiences and knowledge with other users.
User_510641
Is it possible to create a flat roof?
User_510641 2014-03-06 22:03:31
I'm new and I would like to know, if it's possible to create a flat roof..
John
John 2014-03-07 10:24:43
To create a flat roof top you can choose between these two options:
- a simple horiziontal slab to which you can assign the texture for your roof top
- use the "Roof" object and assign a 0 degree inclination.
Best Regards
ACCA Technical Support team
User_538714
User_538714 2015-07-14 15:27:10
Hi,
I have been helped a lot. I'm glad I have seen this about how to create a flat roof. but your last explanation of how to draw a roof left me baffled a lot. This video helped a little: "Rooftop with overlapping roof slopes." But I need lots of practice to connect the roof slope or the walls to the roof. However, is there no video for this explanation: "to customize your roof manually you can draw the slopes and then use the slope detection through three points."?
John
John 2015-07-15 09:00:42
Here's the video you're looking for showing how to set up a roof slope through 3 points:
video.accasoftware.com/EN/edificius/id10/index.html?idPLV=268&autoplay=1
