User_1286551 | Where can I find tool creating construction grid linesUser_1286551 2022-03-14 04:36:14 Hi all, Could you please let me know where I could find the tool in creating construction grid line such as grid line 1, 2, 3, 4 horizontally and gril line A, B, C, D vertically. |
madoniaivan | madoniaivan 2022-03-14 10:02:03 Hi There please have a look at the attached image, if you need to insert the grid labelling in the level then: - insert a 2D grid (arrows 1, 2 and 3) - select the inserted grid and you will find on the properties panel, under the characteristic box a section dedicated to the labelling, (arrow 4) if you need to visualize this grid ALSO in the floor plans (or other drawing models) then: - choose the edit option under the stile menu of the toolbar (arrow 5) - turn on the light bulb related to the 2d magnetic grid (arrow 7)470395_1647248431_griglia_con_labels.png |
