Alvaro Celis | How to switch the program's language?Alvaro Celis 2021-10-05 14:27:52 Hi everyone, The more I model in Edificius the more I love it. I'll sometimes need to generate documentation in Spanish, so I presume the info in the details changes according to the program's language, how can you change it? Or do you need to download a separate version of Edificius? regards, Alvaro |
Tony | Tony 2021-10-05 15:51:42 Yes, you can change language by simply downloading this version here (exactly the same as the English version with same functionalities, etc). Simply Login using your same ACCA account credentials. Services are the same and can be accessed here in Spanish too: support.accasoftware.com/es/edificius/ Regards |
Alvaro Celis | Alvaro Celis 2021-10-05 15:54:50 Thank you, I just ran into the Spanish installer as well. Can you have the 2 versions installed at the same time? regards, Alvaro Edit: it would be great to have the different languages available in the same program, and make it a selectable option from preferences. |
Tony | Tony 2021-10-05 16:06:00 Yes you can do that but if you have 1 license seat, you need to logout from one and back into the other and Visa-versa. |
