Problems when viewing large filesize exported Videos
John2015-06-05 09:09:29
Here's another important technical support issue that I wanted to share with our users.
Question: The video created with Edificius, apart from being large in filesize, isn't reproduced correctly. Is tere something I can do to avoid this?
Answer: Per esportare correttamente un video occorre avere installato sul proprio computer un codec adeguato. Pertanto, suggeriamo di You can try installing an appropriate CoDec and we suggest using "codec pack K-Lite" which is also free. Proceed as follows:
- download the "K-lite" installation package which can also be found easily on the internet; - launch the installation process; - select "Advanced mode"; - click "next"; - select the install folder; - click "next"; - select "Profile 7: Lots of stuff"; - click "next"; - click "next" in all the following windows without changing the default settings; - click "end".
When producing a video in Edificius, in the video settings dialog, select "XVID" as described in the attached screenshot:
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
