Cosimo | How to insert the internal façade guardrails and toeboardsCosimo 2019-09-06 09:50:55 This technical support ticket was sent in by one of our users. REQUEST I need to add extra safety devices to my Scaffolding project. How do I insert guardrails on the inside of the scaffolding? ANSWER To insert the internal façade guardrails, select the object "guardrails" from the objects menu but remember that before applying them on the scaffolding, you must first: - go to the properties panel on the right - position - set the Insert position field option to Rear - then apply the guardrail devices to the scaffolding sections by clicking on highlighted areas. Click Here to see an illustrated image of the procedure. |
